8 bit- 8 bit division (Need 4 bit float point) code for VHDL
hunterboy
Newbie level 1
Hi guys, I am a student in a Technical University and I have a homework to be done but I couldnt handle the stuation so far :) . I need your HELPPPP
The problem is simple. I have to do a divison by 8 bit vector divided by another 8 bit vector and the out put will be 12 bit vector (We must see result after coma (float)).
Thank you all for your concern :???:
FvM
Super Moderator
Staff member
Bochum, Germany
You shouldn't expect others to do your homework, but help is surely available.
First step would be a clear specification. You can design a divider to give fractional result bits (bits right of the decimal point), however this has nothing to do with floating point number representation. Floating point involves an exponent, showing how many bit positions the result mantissa has been shifted. You should also clarify if signed or unsigned division is intended.
A simple way to get 8 integer and 4 fractional result bits would be to extend the dividend by 4 LSB zero bits and then perform a regular integer division.
