74 TTL ICs in xilinx webpack
7rots51
xilinx ttl
How we can use 74 TTL ICs in ISE webpack 7.1 (xilinx)? Is there any available library including 74 series for xilinx webpack?
where to +buy ttl discrete logic chips
74xx not include in xilinx library.If u want u can compile in new symbol.
chip ttl 7400 en vhdl
you can find in TTL library start with x74_
74ls series logic ics
any body have source code of 74xxx vhdl in behaveior.
74 library for xilinx
CAUTION...
The legacy 74XX logic-ICs, i.e. the actual discrete DIP chips you could buy from neighborhood electronics store, use 5 volt TTL signalling.
Modern (since Spartan 3, Virtex 4) Xilinx FPGAs are not compatible with 5V TTL! If you connect your FPGA to 74XX chip directly, you will damage/destroy the FPGA. (You can make the Xiilinx FPGA's 5v tolerant by adding series resistor to the I/O pads. But the FPGA will still send out 3.3v signalling-levels.)
Also, most companies that sell 74XX now sell CMOS (3.3v) versions of those chips. Those are safe to use with the Xilinx FPGA.
