electronproton
Newbie level 6
connect 2 seven segment to 8051
Yes, i'm using pnp transistor..
My circuit is attached..
thx
thx
Yiu should put resistors with resistance aproximatelly 6R7 between outputs A...G and pins of microcontroller.electronproton said:My circuit is attached..
You can design and test software and hardware using emulators (Proteus for example). And use programmer only for prototyping.minge said:...the problem is that i don't have programmer circuit...
