7-Segment Display Problems
imranahmed
Advanced Member level 3
Karachi,Pakistan
Please let me know about the 7-segment display (SEC2414NK 11A, SENIOR).
I cannot find its datasheet on internet.
Please anyone interested to tell me about it?
If the datasheet for the display is unavailable, you can try to figure out the pinout by experimenting. The middle pins will most probably be the common anode or common cathode. Connect those to +V or ground and connect the other pins to ground or +V with a series current-limiting resistor and see which segments light up when. Then, you can deduce the pinout.
Hope this helps.
Tahmid.
