metals
Junior Member level 2
- Joined
- Jan 25, 2011
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,441
Hello, So I have done some exercies / assignments but I dont have the correct answer for them. Can anyone please help me check if I have solved them correct? I would truly appreciate it.
No. 1
Question:
Type in the the new content after the asm-code have been executed.
Is the after column correct?
No. 2
Question:
implement the following pseudo code with assembly code:
My answer:
or
No. 3
Question:
which ASCII-character is being sent? Method is serial communication with RS232. There is a stop bit, start bit, and a parity.
My answer:
ASCII character '&' which is 0100 0110
No. 4
My answer:
No. 5
Question:
You are about to send the ASCII-character 'G' with serial communication RS232 standard.
Draw in the picture below how it would look like.
My answer:
'G' in ASCII is 0100 0111
Should a switch the high and low bits? like this 1 11100010 0?
No. 6
Question:
We want to send the ASCII-character 'B' with serial communication RS323 standard. The parity is odd. Draw the pattern in the following pic
My answer:
ASCII 'B' = 0100 0010
or should I swap the High and low bits before I draw the pattern?
No. 1
Question:
Var1 equ x20
Var2 equ x21
Var3 equ x22
Status equ x03
VarA equ x28
VarB equ x29
VarC equ x2A
[INDENT]movwf Var1
movwf Var3
bsf status,0
rrf Var3
rrf Var3
movlw x3B
addwf VarA,0
movwf VarB
xorfw VarC,1[/INDENT]
No. 2
Question:
if PortC bit2 ==1
(increment var1 by 1)
else
(increment var1 by 2)
My answer:
Code ASM - [expand] 1 2 3 4 btfsc PortC,2 incf var1,f addlw x02 addwf var1,f
or
Code ASM - [expand] 1 2 3 4 5 btfss PortC,2 goto add incf var1,f add movlw x02 addwf var1,f
No. 3
Question:
My answer:
No. 4
if (var1 > 9) or (var1 < 4)
(increment PortC by 5)
else
(invert PortC)
My answer:
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 movlw x09 cpfslt var1 goto add_5 comf portC movlw x04 cpfsgt var1 goto add_5 comf portC add_5 movlw x05 addwf portC
No. 5
Question:
My answer:
No. 6
Question:
My answer:
