Basma Gamal
Newbie level 3
hi all I am kind of newbie in design so I need to check if i got the design steps right or I miss anything..
my goal to design 65nm inverter and calculate rise time fall time delay power and characteristic curves for research purpose not just a lab.
first I searched for software used in paper I found cadence ic design tools or synopsis ic designer and i need 65 nm pdk (cdk) which i don't have access to any of software nor the pdk
so I have access to hspise so i started to learn it and select bsim v3.3 as mos model i read avent (hspise manual ) and took library card in bsim3.3 section and put it in text file and attach it to my desgin
the questions are :
Am i doing anything wrong in steps or are there any simpler method (apart from pspise ) ?
there are errors in including the model file to my design should i change source of model or the extension of file ?
finally thanks in advance ...grin:
:smile:
the questions are :
:smile:
