62256 Ram Problem - not able to read the contents
shashavali_m
Member level 4
62256 ram
Hi
I have interface the 32K RAM 62256 to a controller 89C55, but i am not able to read the contents from it. Dont know whether its written properly or not. Its always read lower byte of the address which it needs to access.
Plz help me how to sort out this problem.
Please share if you have any RAM test program
Thanks in Advance.
hock
Advanced Member level 2
India
62256latch
for testing the RAM
for start of memory to end of memory
write 0xAA (1010101010)
NOP
read from memory location
check if != 0xAA --> memery bad
write 0x55 (0101010101)
NOP
check if != 0x55 --> memery bad
if no error memory is OK
hock
IanP
Advanced Member level 5
West Coast
port 62256
Maybe the problem lays in the hardware.
I hope you are aware that Port[0] is the multiplexed low order Address and Data bus during access to external memory and you have to use 74373 demultiplexer to latch the low order address (A0 to A7) ..
See attached picture ..
Rgds,
IanP
