KJ6EAD
Advanced Member level 3
Since the signal you are referring to is fully rectified from a 60 Hz sine wave, it presents as a 120 Hz ripple.
First, determine if the hum is from the power supply or the input signal. Swap in a battery as the supply or try a battery powered input to make this determination. Make sure your signal input is shielded and that the shield is connected to the same ground point as the amplifier.
Hum caused by battery eliminator output voltage ripple should be 120Hz. If it is 60Hz then your battery eliminator is defective (one of diodes in rectifier is broken). Most often cause for 60Hz hum are ground problems with your audio equipement. Ground potentials (chassis potentials) for audio equipement are different (sound source, amplifier), they are not connected, grounded in one point and thus between grounds flows 60Hz current causing the hum in audio. I presume you are using PC as sound source.
Borber, read before posting please.
