6 V to 100 V voltage convertor
amayilsamy
Advanced Member level 1
Chennai,India
Dear friends, I need power supply for given spec:
I/P Voltage = 6 V to 9 V
O/P Voltage =100 V
O/P Current= 50 mA
Help me how make above power supply?
There is the boost converter. It works by sending current pulses through a coil and taking advantage of the inductive kick after a pulse ends.
Your output is 5W of power. Your 6V supply must provide around 1A.
If you do a search on 'boost' you will find several threads about this type of converter.
Thanks. And I also have one more doubt there is any chance to make that power supply without inductor.
If I choose a boost converter Please suggest the Boost converter IC. I need a 2W output power that is enough for my application 100V @ 20 mA.
There is the voltage multiplier using several Villard stages. But it will not step 6V up to 100V. Too many diode drops.
Or you could build a series of push-pull charge pumps, to boost 6V to 11V, then 11 up to 21, then 21 up to 41, then 41 up to 81, with something additional to reach 100V.
Or a combination of the two above methods.
When you realize all that work conceivably could be done by a single coil, then a boost converter doesn't sound so hard to make, does it?
Please provide the schematic using boost converter with single coil.
This simplified schematic shows how a boost converter would accept a 6V supply, and provide 100V at 20 mA.
It is common to use a control IC that automatically switches the transistor/mosfet at the necessary duty cycle to maintain desired output level.
