T
treez
Hello,
Do you believe that the MCP1703 (sot89) 5v regulator can deliver 5V to a circuit which is pulling zero amps through it? (not loading it at all?)
Figure 5 of the datasheet (fig 2-3) appears to suggest so.
Its just that im using it to supply a few CMOS chips and wonder if at start up, before much load current is being pulled, maybe the output is going over 7V sometimes, above the abs max's of the chips being supplied, (though scoping doesn't show this.)
MCP1703 datasheet
MCP1703 datasheet
