[SOLVED] 555 Timer Monostable 5V to 3V !!!!!!!!!!
Englewood
Full Member level 3
Hello All.
I have made a Monostable 555 circuit that runs on 5V and works fine, lights up my laser.
I need to run the circuit from a 3V battery CR2032, when I use 3V the laser doesn't light up.
Should I use a transistor?
Is the 555 timer not cable of running on 3V?
The laser works on 3V fine out of circuit.
I don't want the circuit to draw too much current from the battery at the moment its drawing 20mA.
Thanks
The datasheet should tell you.
I don't know...I'd need to read it, too.
Klaus
Sorry, I think I just found the problem.
The minimum voltage is 4.5V so NO.
The ICM7555, TLC555 and LMC555 are Cmos and are all the same. They work with a supply as low as 2V but then the output current is low.
Thanks for the reply's.
I have used a TLC555IP works perfect :).
