ZOGAM
Hello friends,
The attached diagram is a 555 IC which output HIGH i.e. LED is ON when toggle switch is pressed, and when pressed again, the output changes to LOW i.e LED is OFF.
As per the attached diagram, I have setup the circuit on breadboard with 0.01 mF ceramic capacitor added between pin 5 and GND. Hence, everything works well fine as supposed to be.
However, I noticed some weird behaviour/strange things as discussed below:
1. With the LED ON or OFF, when either the positive or GND of the power supply is touched through TWEEZERS, the LED turns on and off correspondingly. So, I add a 100 nF ceramic capacitor between pin 2 and GND. Yes, this issue is solved PARTIALLY.
2. Again, in this case, with LED ON, when either positive or GND of the power supply is tapped again, the LED turns OFF immediately. Is not it supposed to stay ON? Because the toggle switch is still maintained at open position. The LED is supposed to be OFF if and only when the switch is closed. So, in this particular case, how to fix this issue of LED turns OFF when either positive or ground side is tapped???? However, with LED OFF, the LED remains OFF even though the said wires are tapped individually.
3. And last one, I noticed is that, with LED ON, I hold the pin 2 and once again, tapped the aforementioned wires. Surprisingly, in this case, the LED CONTINUES to remain in ON state. But when I remove my hand from pin 2 and do retapping on the said wires, the LED turns OFF. This is something weird behaviour. Still I got the same issues when I hold the positive side of the 1 mF capacitor or both with pin 2.
So, please thoroughly read the information and help me out to fix these issues
