555 astable oscillator mode; help with debugging
hardca
Newbie level 1
I am having trouble with the output amplitude on pin 3 decaying to nothing in about 10 seconds once the power comes on.
The application is to have the 555 serve as a gated oscillator and create a 38 Hz carrier for the pulse codes from an IR detector. The output then drives an IR LED to serve as a wired IR repeater for my TV cable box.
lm555 gated oscillator
You forgot to attach a schematic showing the supply voltage, a supply voltage bypass capacitor and the load current.
Are you using a normal high-power 555 or a low-power Cmos 555?
Hi hardca !
On the following links you will find many sugestions about use of 555 timer.
http://williamson-labs.com/480_555.htm.
Good luck.
