50Hz PWM Inverter using pic18F452
umersohail381
Newbie level 2
Abbottabad, Pakistan
I am trying to build a 50Hz pwm inverter using PIC18F452, I have generated spwm by using loops to control Ton & Toff. but its frequency of siusoid(achieved after filtering spwm) is 41Hz due to delay created by code.
How can I generate exactly 50Hz frequency using CCP module of PIC18F452?
U can refer me some book.
Rgards
Umer
I think you are going on with an infinite loop and there you are doing your updates and corrections, If so, then I would suggest you to use interrupts to get an exact timing.
