[AVR] 500ms delay using timer in ATMEGA8
djc
Advanced Member level 1
India
Can somebody guide me how to generate 500 ms delay using any of the timer like Timer 0 or Timer 1 of ATMEGA8.
For ATMEGA8 at 8 MHz Clock.
Code C - [expand]
8
9
10
11
12
13
14
15
//Timer1 Prescaler = 64; Preload = 62499; Actual Interrupt Time = 500 ms
//Place/Copy this part in declaration section
void InitTimer1(){
  SREG_I_bit = 1;
  TCCR1A = 0x80;
  TCCR1B = 0x0B;
  OCR1AH = 0xF4;
  OCR1AL = 0x23;
  OCIE1A_bit = 1;
void Timer1Overflow_ISR() org IVT_ADDR_TIMER1_COMPA {
  //Enter your code here
Thank you jayanth and nick, i am able to generate 500ms interrupt now.
hi jayanth,
I am again facing a problem in timer reload value. Now i want to generate 1sec output compare interrupt. So how to calculate timer reload value. Please guide me.
Thanx alexan,
I found the fault where i was actually lacking.
