Georgy.Moshkin
Full Member level 5
Hello all! Some time ago I used this online calculator: **broken link removed** (currently offline, but I have saved web page with calculator script). I noted that if all parameters kept constant then 50 ohm line width decreases with increasing frequency. Surprisingly linecalc tool in QUCS or ADS gives opposite result: 50 ohm line width increases with frequency.
For example: substrate thickness h=1mm, er=4.3.
Sphere.ne.jp calculator gives:
9mm at 5GHz
1.6mm at 10GHz
QUCS/ADS linecalc gives:
2mm at 5GHz
>2.2mm at 10GHz
Linecalc gives line width similar to well-known formulas for calculating microstrip line impedance. But I am intrigued with sphere.ne.jp calculator, it seems have different approach. Which result is correct? Should line width increase or decrease with increasing frequency?
9mm at 5GHz
1.6mm at 10GHz
2mm at 5GHz
>2.2mm at 10GHz
