I have three 12 volt ignition coils that produce about 15,000 volts each, and I wired the outputs together, and and I turn them on using a relay activated by 12 volts.
I need to pulse the 12 volt lead in at about 5 - 15 hz. I know nothing about electronics, other than very basics (like hz means cycles per second). The lead in voltage is provided through a relay, that is activated by a sensor.]
The whole idea of this thing is to use it as a fish shocker. Anode and cathode sitting on the surface of the water about 10 feet apart, zapping everything that swims by.
Any help really appreciated, and will keep you updated on my progress right here
MOD: Do not post or exchange any projects which are destructive in nature. This thread is locked. Next time i see any such requests or posts, the OP as well other memebers supporting it will be banned.
