There is no single pulse to control 5-phase stepper, you need more than that .. see attached diagram ..
Could you make your question more clear?
Also, see: 5-Phase Stepper Motor Driver ICs http://www.datasheetcatalog.org/datasheet/Sanken/mXqsuvu.pdf
ok i will write code for my pic to run signal which written prototype
Terminal 1 +++-----+++++-----++
Terminal 2 --+++++-----+++++---
Terminal 3 +-----+++++-----++++
Terminal 4 +++++-----+++++-----
Terminal 5 ----+++++-----+++++-
