zuirgham
Junior Member level 3
Refer to the schematic.
In the previous version of the board, I'm getting 5.068 volts as output voltage which is also designed using TPS54331. The newer version of the board also has the same components, but I'm getting 5.111 volts as output voltage.
VDM=Vin=8.084V(Older Version)
VDM=Vin=8.606V(Newer Version).
I removed L4 so that the circuit is isolated from the rest of the board, still, I'm getting 5.111 V as output. Also I Tried the same thing with the older version board, i'm getting 5V with no issues. Could it be something to do with the design of P.C.B? I consulted the P.C.B designer, he said both versions have a similar layout. No changes. Can anyone suggest what might be happening?
