4x4 Hex keypad interfacing
cyrrah
Junior Member level 2
hi.. i just want some advice/suggestion on what port will i interface my 4x4 he keypad.. im using pic877a.. i have port b & d available.. which port will i use? and how will i connect it? pls guide me
You would look at some along these lines. But change the port used, in you case I would most probably use Port B
if ill use portB, do i still need pullup/pulldown resistors? if yes, at what pins will i put it?
can it be done without any external resistors? i just dont understand what's the use of resistors coz some layouts ive seen does not use it.. can you please enlighten be about this matter? thanks
The resistors offer some protection against short circuit of the pins.
An example of what you would do with the above.
set pins B0-B3 as outputs, pins B4-B7 as inputs
Set B0 to high, check the inputs for key press and respond if required.
Set B1 to high, and check inputs & respond
Set B2 to hign, check inputs & respond
Set B3 to high check inputs & respond
There a few ways you could handle the above, depending on what you wish to achieve.
