4A low cost H bridge to drive Stepper motor
ismu
Full Member level 2
nil
i need a 4A low cost H bridge to drive Stepper motor per channel ,can any body suggest cheaper solution ? L298 has only 2A per channel.
srizbf
Advanced Member level 5
look for toshiba TB6600 IC based drivers.
they are 4.5A rated.
(many 3d printers /cnc make use of this board)
KlausST
Super Moderator
Staff member
I used the selection tool of farnell. The same could you do. There are many other distributors and manufacturers with selction tools.
Look at STK672-640A.
Klaus
Noman Yousaf
Full Member level 4
Lahore Pakistan
i think you can use FET based h bridge instead of IC that can be upto 100s of amps.
I have made that by using 75NF75 and IRF4905 FETs.
ismu
Full Member level 2
nil
how you manage dead time, through software or hardware ? is it sufficient to give a cap on one mosfet gate to manage hardware dead time ?
