neazoi
Advanced Member level 6
hello I need to build a 0, 90, 180, 270 degrees phase shift network for 455KHz.
I could do it with a dual flip flop dividing a 1.82mhz crystal down to 455khz in 4 phases but the 1.82mhz crystal is obsolete.
Another way I am thinking is to make a 455KHz crystal oscillator and take the 180 degrees phase out of the collector to drive an amplifier.
Then another amplifier will take the 0 degrees from the emitter and drive another amplifier. At the ends of the two amplifiers I will have 0, 90, 180, 270 degrees phase shift.
Is my consideration right or do you propose another schematic?
