I am trying to convert a 6MHz signal at 44MHz to 50MHz. I assume the best way to do this would be to convert the 44MHz signal to a frequency around 100-200MHz that I can find a standard 6MHz filter at. I guess I would require two frequency synthesizers (PLL+VCO) that work 6 MHz apart. I am not sure if I can use standard cyrstals that are seperated by 6MHz, and use multipliers to achieve this.
If this 6MHz signal is a video signal you can consider first, demodulation to a baseband video and then modulation with 50MHz carrier ..
Other option is to mix 44MHz with 6MHz and filter out all other products (including oryginal 44MHz) except 50MHz product. Here, as the frequency is not that high, you can consider, say 5-pole (or more), active band-pass filter ..
Regards,
IanP
It is a 6MHz digitally modulated video signal, therefore too expensive to demodulate and remodulate.
It will be combined with another 44MHz carrier, so filtering the 50MHz carrier will be very difficult in order to remove all the energy adjacent to it.
