Difference between ASIC and FPGA
vijaytanjore
Member level 1
India
difference between asic and fpga
Hai Everyone
What is the difference between ASIC RTL code and FPGA RTL Code
bcaz i think the RTL code for ASIC and FPGA are same
In What way it differs from each other
Thanking in advance
regards
Vijayakumar
VALGHA VALAMUDAN
difference between fpga and asic
Please goto the following links, they are usefull for your question. And then, do not forget click on help button, it is usefull for me. :)
asic fpga difference
In fact, the subset of synthesizable Verilog/VHDL is IEEE standard or industrial standard. In most cases, don't worry about it. You could use the same code for FPGA or ASIC. However, in the real lab work, you have
- Keep in mind the device specific feathers (FPGA) and the techology specific features (ASIC), if you used the hard block or IP, most frequently memory, you have to see if they are the same.
- the tool specific feathers. You are using different tools in synthesis the code. Some tools provide the tool specific directives, if you use some of them, change your code if neccissary.
FPGA always use "one-hot" statemachine, but done worry about it. Most tools could change it automatically. :)
difference fpga asic
So the short simple answer is very little differnce. That's the whole point of HDL; technology migration without much recoding.
differences between asic and fpga
fpga is a kind of programmable asic.
difference asic fpga
soccer,
The original poster was asking about the difference between "ASIC RTL code and FPGA RTL Code".
The answer is that with RTL code, the answer is, there isn't much difference.
That's one advantage of RTL, technology freedom, common language.
rtl coding fpga asic differences
You can write "pure" RTL that is usable for both FPGA and ASIC, but if you want to take advantage of some special stuff available on FPGAs you may have to customise your code to suit the FPGA architecture of your design
Thinkie, agreed. Likewise for ASICs.
difference between dsp and fpga
Hi All,
Since gated clocks cant be implemeted in a FPGA, I guess we need to take care while using ASIC code in a FPGA flow.
Regards
comparison between asic & fpga
FPGA architecture implies use of digital signal processing
what is difference between asic and fpga
FPGA for DSP, isn't it obvious? Digital Systems for Digital Signal Processing, what else? :D
difference between fpga asic
the design will optimize by the FPGA(ASIC) Lib
so the deisgn will have little difference
lincolndsp,
FPGA imples DSP? I don't think so..
coolrak,
I'm not sure about that. I believe gated clocks can be implemented in FPGA's. In Spartan and Virtex parts at least.
differences between fpga and asic
i want full topic of the FPGA and ASIC ,CMOS .,
Difference between ASIC and FPGA.., send with mail id sir., srichandranid@gmail.com
