[SOLVED] 4 wire resistive touch screen interfacing with ATmega32
tahertinu
Member level 4
Member level 4
Ahmedabad
hello every-buddy,
I am working on project interfacing touch screen with ATmega32. i have used this code
#ifndef F_CPU
#define F_CPU 8000000UL // or whatever may be your frequency
#endif
#include <avr/io.h>
#include <util/delay.h>
#include <stdint.h>
#include "lcd.h"
#define LTHRES 500
#define RTHRES 500
// initialize adc
void adc_init()
    // AREF = AVcc
    ADMUX = (1<<REFS0);
    // ADC Enable and prescaler of 128
    // 16000000/128 = 125000
    ADCSRA = (1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
// read adc value
uint16_t adc_read(uint8_t ch)
    // select the corresponding channel 0~7
    // ANDing with '7' will always keep the value
    // of 'ch' between 0 and 7
    ch &= 0b00000111;  // AND operation with 7
    ADMUX = (ADMUX & 0xF8)|ch;     // clears the bottom 3 bits before ORing
    // start single conversion
    // write '1' to ADSC
    ADCSRA |= (1<<ADSC);
    // wait for conversion to complete
    // ADSC becomes '0' again
    // till then, run loop continuously
    while(ADCSRA & (1<<ADSC));
    return (ADC);
int main()
    uint16_t adc_result0, adc_result1;
    char int_buffer[10];
    DDRC = 0x01;           // to connect led to PC0
    // initialize adc and lcd
    adc_init();
   lcd_init();
  // print some text
  lcd_set_cursor(0, 16);
  lcd_putstr("128x64 LCD");
  lcd_set_cursor(2, 16);
  lcd_putstr("HELLO");
  lcd_set_cursor(3, 16);
  lcd_putstr("WORLD");
    _delay_ms(500);
    while(1)
    {	DDRA |= (1<<DDA0);
        DDRA |= (1<<DDA2);
		DDRA &= ~(1<<DDA3);
		PORTA |= (1<<PA2);
		PORTA &= ~(1<<PA2);
		adc_result0 = adc_read(1);      // read X
		DDRA |= (1<<DDA0);
        DDRA |= (1<<DDA2);
		DDRA &= ~(1<<DDA3);
		PORTA |= (1<<PA2);
		PORTA &= ~(1<<PA2);
        adc_result1 = adc_read(0);      // read Y
        // condition for led to glow
        if (adc_result0 < LTHRES && adc_result1 < RTHRES)
            PORTC = 0x01;
        else
            PORTC = 0x00;
        // now display on lcd
        itoa(adc_result0, int_buffer, 10);
		lcd_set_cursor(4, 11);
  		lcd_putstr(int_buffer);
        itoa(adc_result1, int_buffer, 10);
        		lcd_set_cursor(5, 11);
        _delay_ms(50);
IT'S not working please tell me where im wrong?
Quite mysterious how you want to read both x and y voltage with identical bit settings of PORTA?
We would expect 4 pins flipped between in- and output mode concurrently.
DDRA |= (1<<DDA0);
        DDRA |= (1<<DDA2);
		DDRA &= ~(1<<DDA3);
		PORTA |= (1<<PA0);
		PORTA &= ~(1<<PA2);
		DDRA |= (1<<DDA3);
        DDRA |= (1<<DDA1);
		DDRA &= ~(1<<DDA2);
		PORTA |= (1<<PA1);
		PORTA &= ~(1<<PA3);
sorry there was typo error.
still this is not working. what about fuse bit for ADC operation. should i desable Jtag?
i am stuck here because of Resistive touch screen. please someone throw light on my work and tell me where i am doing wrong. I have interfaced 4 wire resistive touch screen to microcontroller ATmega32 at PORTA0-to-PORTA3. i am getting 1023 and 1023 and some times 1022 on my graphical LCD which is connected on PORTD and PORTB. Here is my code.
// initialize adc
void adc_init()
// AREF = AVcc
ADMUX = (1<<REFS0);
// read adc value
return (ADC);
int main()
adc_init(); // initialize adc and lcd
// Wait a little while the display starts up
for(volatile uint16_t i=0; i<15000; i++);
// Initialize the LCD
ks0108Init(0);
// Select a font
ks0108SelectFont(Arial_Bold_14, ks0108ReadFontData, BLACK);
// Set a position
ks0108GotoXY(15,10);
// Print some text
ks0108Puts_P(PSTR("***TAHER***"));
// a nice little round rect
ks0108DrawRoundRect(5, 5, 100, 20, 8, BLACK);
_delay_ms(500);
ks0108ClearScreen();
while(1)
DDRA |= (1<<DDA2);
DDRA &= ~(1<<DDA3);
PORTA |= (1<<PA0);
PORTA &= ~(1<<PA2);
_delay_ms(10);
adc_result0 = adc_read(1); // read adc value at PA0
ks0108GotoXY(10,10);
ks0108Puts(int_buffer);
DDRA |= (1<<DDA1);
DDRA |= (1<<DDA3);
DDRA &= ~(1<<DDA2);
PORTA |= (1<<PA1);
PORTA &= ~(1<<PA3);
_delay_ms(10);
adc_result1 = adc_read(0); // read adc value at PA1
ks0108GotoXY(10,30);
_delay_ms(500);
please help me to read touch screen co-ordinates when touched
thanks.
tell me where i am wrong please its urgent.
