As already recommended:
I'd use one of the 4..20mA measurement circuits.
But if you want to build your own:
I'd use low side sensing
But if you want higb side sensing:
I'd use an unidirectional sensing chip
Your configuration has some drawbacks. This makes it difficult to use your circuit.
One drawback is the 2.5V offset.
Either you live with it (it's the easiest method).
Then just feed the MAX_output to the ADC and subtract the offset from the digital value.
If you want to subtract it on the analog side, then I recommend a difference amplifier. (Opamp circuit)
But it has also drawbacks:
To be able to measure close to zero Amperes you need a rail to rail output opamp.
To be able to measure true zero, then you need a negative supply voltage for the Opamp, (and protection circuit for the ADC)
Klaus
