geozog86
Member level 3
Hello! I am designing a clock, and i have some questions before moving to the layout part
1--i want to be able to drive a big (12p) load. My most "correct" node to take the output is the comparator output, but i don't want to load it so heavily. So what do you think would load my comparator output as little as possible and be able to drive such a load? Just an inverter? A latch? (i have symmetrical outputs on my comparator)
2--i want to simulate and check my jitter and my phase noise. I mostly find in the internet special equations and theory, and no practical help on cadence: which analysis for example? On a simple clock signal (i see special help when designing a VCO or a PLL....i just have an RC oscillator!)
3--i will have to perform some trimming and my idea is to be able to choose from a number of different voltages for my threshold (used for comparison). Do you know any block that can transfer analogue info from input to output? I guess all the blocks (like multiplexers) in my libraries are digital....sounds childish but i'm confused!
Any of the above you can give me an idea about, thx in advance
