4. Implement a 8:1 MUX using 4:1 MUX
research_vlsi
realise 8:1 mux using only 4:1 mux
Hi friends
I want implement a 4:1 mux using 8:1 mux. I have a solution. whether it is correct?
I attached the Logic, see to it and reply.
Thanks & Regards....
realize 8:1 mux using only 4:1 mux
Hi research............
well the Logic you have gone for is not right....BECAUSE one pin is always grounded
which means no chance of selecting 100,101,110,111.......states.....RIGHT
if you write the characteristic table you will realize.........the fault
the method to go is for the grnd pin connect another mux(2 x 1)...
i think this should work
Bye
8:1 mux using 4: 1 mux
Mr.Guru
I accept the point that u said. But for a 4:1 mux the select lines are 00, 01,10,11. If we apply this to S0,S1... we get the ouput, But as u said It will not satisfy the remaining 4.
can u tell clearly...
Regards
Added after 47 minutes:
Hi there is no need to connect the GND pin to another mux, Its an extra harware.
I tell clearly..
S0 S1 S2
0 0 0
0 0 1
0 1 0
0 1 1
1 0 0
1 0 1
1 1 0
1 1 1
Here S2 is grounded.. Now we have the combinations 00,01,10,11, when applyed it works as 4:1 Mux.
Chech it out, if any comment most welcome...
8 1 mux using 4:1
hi,
I think this is how it should be.
Re: 4:1 Mux Using 8:1 Mux
Hi
Ya the logic given will also work..
Thanks...
pls give me
implement 8:1 using 4:1
attach it soon
hey i wanna know the implementation of 8:1 MUX using 4:1 MUX and 2:! MUX..
please reply asap
