I need help with this problem doing described as below:
The user inputs the MOD number using P3.0 to P3.3. The counting sequence is sent to P1.0 to P1.3. Port P3.4 is used to Start/Stop the counting sequence, when the counter stops and then starts again the counter should continue counting from the previous state. Pin P3.5 is used to select the up/down counting sequence.
