4 axis Motion control card help ?
nick703
Advanced Member level 1
surat
hello friend i want to know about motion control card to control my 3 servo motor and 2 steppe motor.
is that any usb communication card available without PCI card to ready maid driver . i want to controlling using PC software at a same time rotate my 3 axis servo motor .
what is the best motion control card and price detail please any one has a perform this type task please share with me and suggest good motion control card.
thanks....
Hello!
thanks....
I have just made a board that can control 4 DC motors and 6 servos in parallel. If you replace
the 4 motors by 2 steppers, it should do it. You can see it in action here (but only 1 DC and 1 servo used in the
demonstration. Look here: https://www.edaboard.com/threads/311569/
BUT: what kind of steppers do you plan to use? How much current?
Dora.
thanks doraemon for your response .
i have to use bipolar stepper motor with using it's driver and also servo motor and it's driver . i have searched lots of company make this type of ready made board but that cost is so high i can not fine any reliable solution . i have to need simple calculation like three servo motor connected in X ,Y and Z direction and 2 stepper motor connected in X and Y direction using slider to move perfect particular degree.
Hello!
Ok, back to my questions:
1. What kind of steppers (bipolar? Unipolar?)
2. How much current do they need?
3. What kind of servos?
4. How much current for the servos?
The board I made can do what you want... depending on the current you need.
I have tested it with small DC motors, and it works fine, but I guess it will not work if you
need, say, 1 amp per motor.
Dora.
PS: by the way, not "it's driver" but "its driver".
Hello!
Dora.
my bipolar stepper motor work with 2.3A per phase and servo motor is ready made with using of its driver like Panasonic.
