4-20mA ..which one is best
dipnirvana
Full Member level 4
India
hello friends ,
I am little confused, i want to design isolated 4-20mA transmitter .
Please tell me as i am new to it , what will be voltage source to ckt , will it come from the receiver or my card has to generate all the voltages.
Also, i seen couple of circuit in which improved howland is used as a current source . But here it's assumed that load is in between ground.
there are other topology where they use simple voltage to current convertor and use a BJT to transmit current.
Please help me with circuit , i don't want to use ICs as i think it will be costlier.
sunyuan
Junior Member level 2
Variable resistor, 24V power supply, ammeter and valves in series. Then adjust the side observed. You can get you current.
