mrinalmani
Advanced Member level 1
- Joined
- Oct 7, 2011
- Messages
- 463
- Helped
- 60
- Reputation
- 121
- Reaction score
- 58
- Trophy points
- 1,318
- Location
- Delhi, India
- Activity points
- 5,285
Hi
We have to design PFC with multiple power outputs ranging from 3KW to 10KW. Input voltage range 160V to 280V and output voltage = 400V. Up till now I have only designed and tested between 200W to 800W. I especially liked CrM topology over CCM, they simply run very smooth and cool.
I was thinking of using an interleaved architecture with roughly 1KW to 1.5KW per channel. This would mean close to 8 channels for a 10KW PF. There are controllers like the UCC28070 that can accommodate several channels( phases) with the help of external phase shifted synchronization signal. But this is CCM not CrM.
- Should I prefer CrM for >1KW PFC?
- Instead of increasing channels as the power increases, would be nice to just stick to say 3 channels and increase inductor and switch size? What is generally done? Increasing channels or increasing component size?
Thank you
Thank you
