The all input out put power supply is working problem is high noise and low gain.Hi,
Read the IC. Find out manufacturer and IC type.
Look for datasheets, descriptions and application notes. Learn how the IC operates.
Then test if everything is like in the descriptions:
* power supply
* inputs
* outputs
* other signals
Klaus
Apparently there's no varcap besides the two trimmers. Is it a fixed channel receiver? In this case, both trimmers must be tuned to set the receiver to a different station.
The datasheet shows the oscillator variable capacitor (to tune the frequency) connects to pins 18 and 19. The RF variable capacitor (to peak the sensitivity at a frequency) connects to pins 19 and 20.
If you replace the trimmer capacitors then the replacements must have the correct capacitance value. With the detailed coils shown your trimmer capacitors should be about (20pF + 30pF=) 50pF.
It is a cheap poor quality radio circuit with high distortion and poor selectivity. Since its antenna input is not tuned (its tuning is after the RF amplifier) then it is overloaded by strong local stations, a local (attenuated) distance (direct) switch is needed.
If you didn't change anything else, you should be able to get an acceptable quality by tuning both capacitors alternatingly.
Probably because it is a very cheap simple circuit.The all input out put power supply is working problem is high noise and low gain.
The datasheet shows coils with a tuning core and low value tuning capacitors. My FM transmitter uses coils with no core like yours but they have 9 turns but your coils have 3 turns and 4 turns. My FM transmitter uses trimmer capacitors that are 5pF to 35pF so try your circuit with trimmer capacitors that are about 56pF maximum.Hello AG,
I never calculated or does not know how to select trimmer calculation
