treez
Advanced Member level 5
We are using the B57234S0509M NTC.
Its for inrush into a 190-265VAC offline flyback SMPS with an input electrolytic capacitor of 150uF.
The schem and inrush power waveform is as attached (this is with mains applied at mains peak and when VAC = 265VAC. (Also, LTspice schem is as attached).
Do you think this NTC can handle this ….how many times?
The datasheet gives no indication of i^2.t or allowable power vs time waveforms.
The 3R inrush NTC energy is 16Joules, and this is over 500us. Datasheet doesn't verify this.
If ambient is 40degc at the time of switch ON, then there is a 33kW peak power pulse (as shown). I strongly doubt that this little NTC can handle this without some damage?
B57234S0509M NTC datasheet
B57234S0509M Datasheet PDF, EPCOS AG :: QDATASHEET ...
Epcos B57234S0509M PDF : Inrush Current Limiter, B57234S0509M Datasheet, B57234S0509M pdf, B57234S0509M datasheet pdf, datenblatt, pinouts, data sheet, schematic
www.qdatasheet.com
