32768 hz quartz oscillator
nikemoto
32768 hz oscillator circuit
hi this my 1st post here.
topic is a watch crystal oscillator for PIC (microcontroller).
i do not want to use logic gates.
here the circuit (a thread on the microchip forum)
https://forum.microchip.com/tm.aspx?m=271212
there are pictures, and small movies of the circuit in action.
it works for 4mhz crystal, using a BSS138 MOSFET. also for ceramic resonators.
but why it does not work for watch crystal?
any hints? please explain. every information helps.
nxtech
Full Member level 5
NO HIDDEN LINKS
32.768 khz oscillator mosfet
Have you checked the drive strength of the crystals you are using. The 4MHz crystal and ceramic resonators most likely are generating enough current to turn the FET on where as the 32khz crystals were not designed to that.
If you truly need to run a FET at 32khz you are going to have to do something to boost the drive strength to turn that FET on.
E
nikemoto
quartz 32768
i understand what you mean. however, the MOSFET is voltage controlled- all what's driven are internal capacities (and they are in the 10pF range).
i do not understand MOSFET, or quartz oscillator completely, true.
is there are better explanation than the equivalent circuit (L-C)?
maybe it would help to add a series resistor?
also i figure out, the circuit can not startup from a programmer board 7805, only from USB power supply (switched by software).
i should also test with 6 volts battery (OK i will hook-up a 9v Eblock later on).
the circuit is here: https://i25.photobucket.com/albums/c69/nikemoto2511/electronics/bss138_oscillator_circuit.png
Fom
Advanced Member level 2
Taiwan
bss138 quarz
I don't know about BSS138, but the most of modern MOSFET switches have about 1nF gate capacitance not 10 or 20 pF.
nxtech
Full Member level 5
NO HIDDEN LINKS
32,768hz quarz
nikemoto, adding a series resistor is not going to help. You need to increase the drive strenght (i.e. voltage) on the gate of the FET to get passed the Rdson resistance.
Look for a FET driver to put inbetween the FET and your oscillator circuit. Personally I would use either a micro or a CPLD to drive the FET.
E
jcpu
Full Member level 4
4069 32khz
hello, nikemoto, please post the circuit again here.
That one at microchip site is not easily read.
What makes 32768 special is it's high impedance (>10 Mohm)
due to much lower freq and that calls for extreme care of driver design.
have fun.
chemelec
Full Member level 4
BC. Canada
32.768 khz oscillator using logic gate
Using the 32.768khz crystal in an oscillator with a 4069 will produce enough voltage to drive the Mosfet.
nikemoto
32768
here the circuit again.
yes i know CMOS gates work for 32768 hz crystal. however, i could also use a PIC directly.
maybe the circuit produces waveforms, but for the LF crystal they are not enough to drive the clock input?
10MOHM*10pf=
10KOHM*10nf=
10OHM*10uf
this should not be impossible for 32khz to oscillate but maybe it is for some reason.
angara
Newbie level 1
32,768 oscillator
10MOHM*10pf=
10KOHM*10nf=
10OHM*10uf
Measure output voltage using some high impedance tool. The voltage should be half of power supply voltage. If not add some MegOms resistor in parallel with the crystal.
nikemoto
testeur quartz 32khz
here also a photography of the circuit. the SMD transistor should be visible. works fine for 4Mhz, but also no startup from transformer based power supply.
https://www.flickr.com/photos/nike6/923812447/
from computer USB startup easily.
i will test with E-Block battery (5 to 6 volts) later on today. the design is not critical, i am just interested in the subject.
you can share the flickr link freely for the purpose to discuss the circuit, or maybe even link to it for reference purpose. however, i do not give a guarantee.
