Falcon177
Newbie level 1
Hello guys,
I am building a circuit that converts from +30V DC source to +12 and -12 V outputs using the 7912 and 7812 ICs (I used the circuit in the 7912 and 7812 datasheets). The problem is that when i tested the circuit the -12V worked properly but the +12V terminal gives a much lower voltage (~7V). I tried adding equal parallel resistors across the 2 capacitors and the I managed to get 9V. Does anyone have an idea why this is happening and what i can do to get the +-12V I need?
Thanks
Thanks
