CMOS
Advanced Member level 3
I am constructing "X10 Home Automation using PIC16F877" (AN236) from microchip. It consists of a transformerless power supply and a zener regulator of 5.1V. Since my country has 230V AC @ 50Hz, I have changed the power supply circuit. Both the original and modified circuits are given below.
Calculations for Irms output from ac coupling capacitor is.
Original circuit : Irms = Vrms * 2 * Pi * f * C = 117 * 2 * 3.14 * 60 * 4.4uF = 194mA
Modified circuit : Irms = 230 * 2 * 3.14 * 50 * 2.2uF = 159mA
The problem I am facing is that when the circuit starts X10 transmission, its current consumption increases from 30mA to about 80mA and voltage drops from 4.99V to 4.1V. But the circuit is capable of delivering 159mA. Even then there is this voltage drop. Due to this the circuit fails to work properly. If I supply the circuit from 7805 regulator and transformer, it works absolutely fine.
Can anyone explain why there is so much variation in the output voltage? Any suggestions to make it stable?
