WeniTheElder
I'm trying to build a 3-stage BJT amplifier to amplify the signal from an electret microphone and drive a 3W, 8Ω speaker. I'm kinda stuck and need some help.
My idea is to use the first two stages as common-base amplifiers, each with a gain of around 15.5. The mic outputs about 20 mV, and I calculated that the speaker needs around 4.9 V peak to deliver 3W, so I aimed for a total gain of about 240. The third stage is a common collector to help drive the speaker.
I chose capacitor values based on suggestions from ChatGPT, and for the resistors I assumed β = 100, VBE = 0.7V, and IC = 1 mA.
The problem is, when I simulate just the first two stages, I get a really distorted waveform, not a clean sine wave at all. I’m not sure if it’s because the gain is too high, or maybe the biasing is off.
Any advice would be appreciated — I just want to get a clean amplified signal before adding the last stage. Thanks!
