dksoba
Member level 2
- Joined
- May 5, 2010
- Messages
- 47
- Helped
- 3
- Reputation
- 6
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,743
On one of my CNC mills I'd like to make a circuit that can detect when the coolant pump (3-phase, 200v) turns on so that I can turn a solenoid valve on/off (basically the solenoid valve will control the air that goes to the spindle's positive pressure "seal"). The circuit will also do a few other things which I would prefer to do with a microcontroller, so I need to be able to detect when the pump turns on.
One way to detect if the pump has turned on is to monitor the input to the solid state relay that turns the pump on/off. Assuming I can't easily get access to that signal, another way might be to monitor the actually wires going to the pump.
My first idea was to monitor one of the phases and use a diode bridge to rectify the AC signal I'd get. Then I'd use a capacitor and resistor voltage divider to get the voltage output to be something compatible w/an optocoupler (I think this would be on the safe side, maybe not necessary). This all seems like it'd work, but I'm only about 70% confident.
Am I on the right path here? Any other suggestions? I don't want to be reinventing the wheel, especially if there's a component I can just buy off the shelf for this purpose.
Cheers,
Matt
Cheers,
Matt
