I am kind of new to FPGA boards, however I have a need where I need to;
1. have three HDMI outputs and one input HDMI port
2. being able to connect three LCD screen later on directly to the board.
Questions are;
1. Is it even possible to have three LCD screens connected directly to the board?
2. If the answer is yes, can someone recommend a board that can handle such a task.
There is no such board which can give you such versatility, however, you can buy some FMC boards along with FPGA boards which support multiple HDMI IN/OUT ports.
If you are able to get an FMC board that can provide you with all the necessary ports, then only one FPGA can be used. Otherwise, you may have to use multiple FMCs and multiple FPGAs
