3 axis gyroscope from ST - L3g4200d
aditya.pogade
Newbie level 2
I am using ST's new 3 axis Gyroscope L3G4200D in one of my application. However I don't have enough documentation available to proceed with the firmware development. Can anybody help me with some test codes, by which I can test the gyroscope.
Thanks in advance!
Best regards,
Aditya Pogade
bunrockter
Newbie level 6
Reactions: jbv55
    jbv55
bepobalote
Full Member level 3
Europe
Please can you tell us where did you buy it?
On Digikey and others vendors it is not yet available... :(
harifenz
Newbie level 1
I am also using the Gyroscope L3G4200D. I am trying to access the sensor via I2C and therefor i need some more information.
On the datasheet there is no information about registers and their addresses.
Thanks for any advice,
Hari
dread_locks
Newbie level 1
I want to use this gyroscope also, but I cant find it to buy anywhere.
Based on past experience on getting hold of fairly new parts, i think you have to sleep with someone from ST in order to get a few samples of the chip.
Right now I'm using an acellerator chip to measure acelleration in a car, but its giving me problems because as soon as the car starts going up or down a hill, the readings start going nuts because of the incline and that darn gravity thing (who needs it anyway sheesh).
I thought of using a high pass filter to solve the problem. Basically take a running average and constanty subtract that from the real-time reading in an attempt to remove the gravity reading from going up or down the slop. But I dont think that will work and and I decide to use a gyroscope.
But of course the lead time for the gyropsocpe is like 6 months to infinity. I dont know how the electronics industry can survive doing business like this.
dread_locks
Hari
dagrende
Newbie level 2
I was just making an order to avnetexpress.avnet.com for 3 L3G4200D, but they wanted $60 to send the letter with the chips to me (in Sweden)! So I backed off.
The chips cost around $8 each.
I really need one of these gyros for a super cool project.
Kevin_C
Newbie level 1
Their latest data sheet now has the Register description included.
dagrende
Newbie level 2
There is another 3-axis gyro: ITG-3200 from invensense.com. It has only I2C interface, so it may be e harder to interface than the L3G4200D SPI.
The iPad has space on the PCB for this device, but it never got there, for some reason.
I tried to order this too, but they wanted $60 postage to Sweden too.
nittvenus
hi i am working with this sensor and I have not been able to program, I am using a PIC 16F877A to receive data through SPI
if anyone has a sample code please post it
dan1st6
Hello
I am new with gyro MEMS.
I need some help how to calculate range from the gyro
data, Can I get some help?
Thank you
:cool:
dan1st6
I want to work with three lpy410al components.
I think that they have better performance than the L3G4200d.
Sensitivity change vs. temperature:
lpy410al=0.07 %/°C
L3G4200d=2%
Rate noise density
lpy410al = 0.014 dps/√ Hz
L3G4200d=0.03 dps/√ Hz
What I dont know if the above parameters are for one axis for
the L3G4200d or a total. It seems that the lpy410al has better
performances than the L3G4200d
nittvenus
get the values ​​of X, Y and Z, but as I get the grades.?
when it is still out values.
anyone know?
nittvenus
I found a good document, but still does not solve my doubt
  • Aplication note L3G4200D.pdf
Reactions: karaca
    karaca
karaca
Newbie level 1
I am new with these kind of sensor applications and I have to drive L3G4200D with a microcontroller.
Do you have any sample code?
nittvenus
here's a code, Karaca greetings from Colombia
  • L3G4200D_Example.zip
