3 and 4 terminal devices in cadence
maninnet
Member level 5
in cadeence NCSU CDK, there are three terminal devices (NMOS and PMOS) and four terminal devices (NMOS4 and PMOS 4), by default, in three terminal devices, body is tied to gnd for nmos and vdd for pmos. if i use four terminal devices, and tie body of NMOS4 and PMOS4 to gnd and vdd respectively, is it equivalent to use the three terminal devices? hope someone can share your experience
aryajur
Advanced Member level 3
San Jose, USA
It is equivalent from the libraries I have used. Haven't used NCSU CDK though but it should be simple enough to confirm by viewing the netlist.
A.Anand Srinivasan
Advanced Member level 5
India
ya it is true... it just serves better when you are gonna avoid body effect that is all... saves a little time....
maninnet
Member level 5
to aryajur: how to confirm "viewing the netlist" ? could you show me?
aryajur
San Jose, USA
In the Analog Artist Window there is a option to view the netlist. In the netlist you can see how each device is netlisted out and what model is it using, you can compare it for both and see if everything is the same or not.
    maninnet
hung_wai_ming@hotmail.com
Full Member level 6
Having four terminal for a device is because you have the chance to connect body other than VDD or VSS, by default, to avoid body effect when you cascode two devices or use it as input pair in OP-AMP. It is the SAME if you connect it back to VDD or VSS as the three terminal device. There is no need to check netlist and it's pretty sure
maninnet
Member level 5
to hung_wai_ming@hotmail.com:
I originally use three terminal device, but when i replace them with 4 terminal device ( all sources of Nmos tie to gnd, and source of pmos tie to vdd), i did not get the same result (new one not working), that is why i ask such a question.
A.Anand Srinivasan
India
try simulating the characteristics of 3 and 4 terminal device separately in some amplifier configuration and maybe you would be able to know the difference and hence the cause of the deviation,,,....
maninnet
Member level 5
i sim DC with nmos device, the result (DC current) is slightly different, please check the picture for schematic and netlist.
aryajur
San Jose, USA
The only difference in the netlist is the gnd! node in one transistor. I am not sure how is gnd! connected to node 0. It should be the same, if it is there doesn't seem to be any reason why the DC characteristics are different. The thing to investigate is how and gnd! and 0 connected does the gnd symbol do that directly or is there something we don't know.
A.Anand Srinivasan
India
cadence takes some value for the resistance of the wire... try playing with it and see whether there is any change in the Id....
maninnet
Member level 5
"takes some value for the resistance of the wire... try playing with it ", but how to?
A.Anand Srinivasan
India
i remember seein it in the properties table..... i dont remember the exact steps..... if i go to my college lab any of these days i'll post the exact steps.....
