mr_anderson
- Joined
- Jan 23, 2007
- Messages
- 100
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 1,298
- Activity points
- 2,005
Hi
I have a 5 volt 2 Mhz signal that is being generated by PIC18F87J60 and PIC16F877A, I am trying to feed that signal to a take an input of 3.3 volts. The problem is the 5 to 3.3 volt converter will take 7 days to arrive so I am trying to come up with a quick solution.
I went through the data sheet of 87J60 and found that it has some 3.3 volts feature but didn't really understand is that for ethernet only or I can have 3.3 on all the pins?
I also tried to connect 4 diodes in series with one 4.7K resistor to get a voltage drop from 5 to less than 3 volts but that is giving some noisy results, any suggestions will be highly appreciated.
Thx.
Thx.
