2x16 LCD Screen Character Background Problem
flashabu
Newbie level 2
Newbie level 2
[SOLVED]2x16 LCD Screen Character Background Problem
Hi guys,
I have a strange problem with displaying text/characters on my blue backlit 2x16 LCD screen. The code is working correctly and if I look the screen with an angle, I can read it. However it cannot be read by looking the screen from above. Here I am attaching the photos of my problem:
I don't put those boxes there and I have no idea where they come from:) Can there be a wrong connection or smth? Any idea?
Thanks a lot
It was the most quick problem solving of mine :D It was because of over voltage. I connect a 4.7K resistor through V0, problem is gone:) If somebody faced such thing, try this.
hello,
try to reduce the back light...by adding serial resitor.
and play with contrast adjustment.
Re: [SOLVED]2x16 LCD Screen Character Background Problem
You haven't adjust the contrast
I agree, the contrast control is set to high, you should set the contrast for a compromise between readability and speed of response, the adjustment between the two is very fine. You should fit a pot and not a fixed resistor otherwise the speed of response is not optimally set.
put 10K trimpot to the GND on LCD VEE pin, adjust it until you can see the best contrast, mostly I put 1K resistor to ground to make it fix....so far it works for me...
