wccheng
Full Member level 5
Dear all,
I have a 2-port DUT circuit. I connect port-1 is a input port and port-2 is a output port. I am using Spectre simulator. During S-parameter setting, it provides a box to select which port doing s-parameter simulation. I found that the Z or Y paramenter simulated result is different if I select just one port or two port in s-parameter simulation. Which result is correct?
I simulated the Y parameter under selecting input port in the s-parameter simulation. And then makes the equivalent circuit and uses it as output loading. I connect this equivalent circuit in my LNA output. The simulation result is same as the actual DUT connects in my LNA output. On the other hand, I simulated the Y parameter under selecting input and output port in the s-parameter simulation. Then makes the corresponding equivalent circuit and uses it as output loading. Also, I connect this equivalent circuit in my LNA output. The simulation result is dfferent as the actual DUT connects in my LNA output. So, it makes me confuse.
Thanks,
wccheng
Thanks,
wccheng
