vijay82
From one of the much vaunted Cliff Cumming papers on reset synchronization of async resets:
It says that because there is no logic differential (input and output are both 0) at the second flop, reset recovery violation will have no affect on its stability.
In a normal flip-flop, even if the input and output are same and setup time (similar to recovery time) is violated, the flop will go metastable. Is it in the nature/character of the reset recovery time that, given that input and output have same values, no metastability will occur if the time is violated? That is, is it a special case?
The second flip-flop of the reset synchronizer is not subject to recovery time metastability
because the input and output of the flip-flop are both low when reset is removed. There is no
logic differential between the input and output of the flip-flop so there is no chance that the
output would oscillate between two different logic values.
