2lcds to one pic - is it possible ?
newbie111
Member level 2
Member level 2
h.k
2lcds to one pic
hi folks
i read something on this site
and connected 2 16x2 lcds to one 16f690
with 2 buttons like in the diagram
it worked on proteus
i do not know if it is workable in a real circuit
Any ideas?
Thanks a lot in advance
Link:
https://www.picbasic.co.uk/forum/archive/index.php/t-626.html
circuit:
wp100
Advanced Member level 6
Prime Meridian
Re: 2lcds to one pic
Don't see why not, used as is, it will display the same message on both screens.
If you modified the code, so each lcds E line had its own dedicated pic pin you could then output different messges to each screen.
    newbie111
GrandAlf
Advanced Member level 2
UK
2lcds to one pic
So long as R/W is held low so that you are only writing to the display and not reading, it should not be a problem, you could have several displays depending on the drive capability of your source. As wp100 says controlling each Enable with a separate pin, would mean that you could decide which or all would display.
    newbie111
possible.vishnu
Newbie level 2
Newbie level 2
lcd with pic 16f877a
hey guys do ull have any working code
for 16*2 lcd interfacing with pic 16f877a
plz its urgent
newbie111
Member level 2
Member level 2
h.k
Thank you all
I finished everything
it worked well
Added after 8 minutes:
possible.vishnu,
I do not know which compiler you are using
i suggest you download mickro basic or c compilers
there are good examples in the " help section"
for a 16x2 lcd , all u have to do is to get to know
how to set pins to digital ( refer to your datasheet if you have no idea how)
anyway the examples will help you
with ease
cheers
GrandAlf
UK
2lcds to one pic
If you are thinking of using CCS compiler, check out their forum and search for flex_lcd, there are a few for different types of display. Even if you are using a different compiler, they should be fairly easy to modify.
