molloy
Member level 3
CATV amplifier
hello,
I need to use the 2F8725D a CATV amplifier in a final stage for a DVBT driver (about 20dBm power output in VHF and UHF band and so in two band from 170 to 230MHz and 470 to 860MHz). The Zin and Zout in our case is 50ohm while the CATV is 75ohm. According to you is it possible simple with a network matching (resistive at the input and reactive at the output)?
regards
hello,
regards
