Serial LCD Problem, text prints slowly
Bangalore, India
I have written a Serial LCD Code which uses 2 wires. The problem is the characters display one after the other and it is very slow. Why does the character print so slowly? I want it to display characters just like 4-bit non serial LCD prints i.e., I need it to print data fast so that it appears as if each line is printed as a whole.
I am attaching my project files and Proteus files.
  • SLCDCD4094.rar
Remove waitUs.
Try modified code in attachment.
:wink:
  • updated-faster.rar
Thanks tpetar. It is much better now. I still modified the code. See below piece of code. I commented out the 2 delays in the for loop. I want to know is it ok to remove the delays in the for loop or is it necessary to have them? I tested it on Proteus after removing the 2 delays in the for loop and it is working perfectly.
I am attaching the new file.
Code C - [expand]
8
9
10
11
12
13
14
15
for ( i=8;i>0;i=i>>1)
                if(d & i)
                                data_ =1;
                        else
                                data_ =0;
                //waitUs(10);
                clk = 1;
                //waitUs(10);
                clk = 0;
  • SLCDCD4094 v2.rar
It should be ok. Thats the problem with Proteus simulator you never know whether it will work or not on real hardware, that's why I always say nothing can replace developing board or protoboard with real hardware. Proteus is good as cheap variant if you dont have hardware, but it may be a waste of time.
Additional you can run uC on faster speed, try 16MHz, existing configuration is for 4MHz. :wink:
Why it is slow when 4 MHz is used? All my C code is around 210 lines and if it is assumed that the assembly equivalent code will have around 2000 line code and each assembly instruction will take 6 clocks then total clock needed is 12000 clocks. 1 sec = 4000000 clocks, 12000 clocks = 3 ms. Even if it takes 3 ms then text should appear instantly.
Because your 'waitUs' function is bad (it is the same as the 'waitLcd') :
void waitUs(int x) {
   unsigned char i ;
   for (x ;x>1;x--)
       for (i=0;i<=10;i++);
So the waitUs(10) is much more than 10 us: outer (x) loop runs 10 times, but the intern loop (i) itself longer than 40 us at 4 Mhz.
See the asm output...
  • 2wire_lcd.zip
Thank you zuisti.
Can somebody explain this piece of asm code.
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
_waitUs:
;slcd.c,346 ::                 void waitUs(int x)
;slcd.c,349 ::                 for (x ;x>1;x--);
L_waitUs14:
        MOVLW      128
        MOVWF      R0+0
        MOVLW      128
        XORWF      FARG_waitUs_x+1, 0
        SUBWF      R0+0, 0
        BTFSS      STATUS+0, 2
        GOTO       L__waitUs32
        MOVF       FARG_waitUs_x+0, 0
        SUBLW      1
L__waitUs32:
        BTFSC      STATUS+0, 0
        GOTO       L_waitUs15
        MOVLW      1
        SUBWF      FARG_waitUs_x+0, 1
        BTFSS      STATUS+0, 0
        DECF       FARG_waitUs_x+1, 1
        GOTO       L_waitUs14
L_waitUs15:
;slcd.c,353 ::                 }
L_end_waitUs:
        RETURN
; end of _waitUs
_waitUs:
;slcd.c,346 ::                 void waitUs(int x)  //[COLOR="#FF0000"]unfortunately (and unnecessarily)
                                                    // the parameter x is a signed int !![/COLOR]
;slcd.c,349 ::                 for (x ;x>1;x--);   //[COLOR="#FF0000"]line 349 in the C source[/COLOR]
L_waitUs14:
        MOVLW      128
        MOVWF      R0+0
        MOVLW      128
        XORWF      FARG_waitUs_x+1, 0 //[COLOR="#FF0000"]the signed 'x > 1' examining is such complicated :-([/COLOR]
        SUBWF      R0+0, 0
        BTFSS      STATUS+0, 2
        GOTO       L__waitUs32
        MOVF       FARG_waitUs_x+0, 0  //[COLOR="#FF0000"]the 'FARG_waitUs_x+0 (and  +1) is the parameter x (2 bytes) [/COLOR]
        SUBLW      1
L__waitUs32:
        BTFSC      STATUS+0, 0           //[COLOR="#FF0000"]if carry then end else continue[/COLOR]
        GOTO       L_waitUs15
        MOVLW      1
        SUBWF      FARG_waitUs_x+0, 1   //[COLOR="#FF0000"]the 'x--' is also such complicated :-([/COLOR]
        BTFSS      STATUS+0, 0
        GOTO       L_waitUs14
L_waitUs15:
;slcd.c,353 ::                 }
L_end_waitUs:
        RETURN
; end of _waitUs
So use here an (unsigned) char parameter!
Ok. Thanks zuisti.
I tried but if I use 10us delay it works upto MCU clock 16 MHz. For 20 MHz LCD display is blank. If I use 20us delay then it works at 20 MHz also.
Serial LCD working at 20 MHz.
