internetuser2k12
Banned
Hello!
This code is reading rfid and displaying it, but comparing it with tag array fails. why?
tag = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 1, 2, 3 }
card_id holds the read rfid.
rfid entered through virtual terminal is 123456789123
here is the code
OK. rfid v2.rar is working but It is displaying Card Accepted 4 to 5 times. why?
OK. rfid v3.rar is working. The problem got fixed, but It is displaying Unique Card Id after displaying Card Accepted. why?
Is the mcu resetting?
OK. The problem got solved. It was the break; statement
Here is the working code and project files rfid worling.rar
here is the code
#include<reg51.h>
//Function declarations
void cct_init(void);
void delay(int);
void lcdinit(void);
void writecmd(int);
void writedata(char);
void ReturnHome(void);
void display();
void display2();
//Pin description
P2.4 to P2.7 is data bus
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P1^0;
sbit E = P1^1;
unsigned char card_id[12];
unsigned char tag[12] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 1, 2, 3 };
unsigned char read_id[12];
unsigned char current_byte = 0;
unsigned int display_flag = 0;
unsigned int key = 0;
unsigned int count = 0;
void recieve() interrupt 4 //Function to recieve data serialy from RS232
card_id[current_byte]=SBUF;
RI=0; // Reset the serial interrupt after recieving the byte
current_byte++;
// Main program
void main(void)
cct_init(); //Make all ports zero
TMOD=0x20; //Enable Timer 1
TH1=0XFD;
SCON=0x50;
TR1=1;
EA=1;
ES=1;
lcdinit(); //Initilize LCD
writedata('U'); //write
writedata('n'); //write
writedata('i'); //write
writedata('q'); //write
writedata('u'); //write
writedata('e'); //write
writedata(' '); //write
writedata('C'); //write
writedata('a'); //write
writedata('r'); //write
writedata('d'); //write
writedata('I'); //write
writedata('d');
ReturnHome(); //Return to 0 position
while(1)
while(current_byte!=12);
display();
delay(50000);
key=0;
for(count=0;count<12;count++)
if(card_id[count]==tag[count])
key++;
count = 0;
if(key == 12) {
display2();
display_flag = 1;
if((tag == card_id) && (display_flag == 0)) {
display2();
display_flag = 1;
void display() // Function to display the unique id
unsigned char count;
writecmd(0xC1); //Place cursor to second position of second line
writedata(card_id[count]);
//read_id[count] = card_id[count] + 48;
current_byte=0;
void display2() // Function to display the unique id
//writedata(tag[count]);
writedata('A'); //write
writedata('c'); //write
writedata('p'); //write
writedata('t'); //write
void cct_init(void)
P0 = 0x00; //not used
P1 = 0x00; //not used
P2 = 0x00; //used as data port
P3 = 0x00; //used for generating E and RS
void delay(int a)
int i;
for(i=0;i<a;i++); //null statement
void writedata(char t)
RS = 1; // This is data
P2 &= 0x0F; // Make P2.4 to P2.7 zero
P2 |= (t&0xF0); // Write Upper nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
P2 |= ((t<<4)&0xF0);// Write Lower nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void writecmd(int z)
RS = 0; // This is command
P2 |= (z&0xF0); // Write Upper nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
P2 |= ((z<<4)&0xF0);// Write Lower nibble of data
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void lcdinit(void)
///////////// Reset process from datasheet /////////
delay(15000);
P2 |= (0x30&0xF0); // Write 0x3
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(4500);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(300);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
P2 |= (0x20&0xF0); // Write 0x2
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
writecmd(0x28); //function set
writecmd(0x0c); //display on,cursor off,blink off
writecmd(0x01); //clear display
writecmd(0x06); //entry mode, set increment
void ReturnHome(void) //Return to 0 location
writecmd(0x02);
delay(1500);
#include<reg51.h>
void delay(int);
void lcdinit(void);
void writecmd(int);
void display();
void display2();
//Pin description
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P1^0;
sbit E = P1^1;
unsigned char tag[12] = { 49, 50, 51, 52, 53, 54, 55, 56, 57, 49, 50, 51 };
current_byte++;
// Main program
void main(void)
TH1=0XFD;
SCON=0x50;
TR1=1;
EA=1;
ES=1;
writedata('d');
while(1)
display();
delay(500000);
key=0;
key++;
count = 0;
if((key == 12) && (display_flag == 0)) {
delay(500000);
display2();
display_flag = 1;
key = 0;
break;
display2();
display_flag = 1;
current_byte=0;
void cct_init(void)
void delay(int a)
int i;
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void lcdinit(void)
delay(15000);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(4500);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(300);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
writecmd(0x02);
delay(1500);
#include<reg51.h>
void delay(int);
void lcdinit(void);
void writecmd(int);
void display();
void display2();
//Pin description
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P1^0;
sbit E = P1^1;
current_byte++;
// Main program
void main(void)
TH1=0XFD;
SCON=0x50;
TR1=1;
EA=1;
ES=1;
writedata('d');
while(1)
display();
delay(500000);
key=0;
key++;
count = 0;
delay(500000);
display2();
display_flag = 1;
key = 0;
break;
display2();
display_flag = 1;
current_byte=0;
//unsigned char count;
//for(count=0;count<12;count++)
void cct_init(void)
void delay(int a)
int i;
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void lcdinit(void)
delay(15000);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(4500);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(300);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
writecmd(0x02);
delay(1500);
#include<reg51.h>
void delay(int);
void lcdinit(void);
void writecmd(int);
void display();
void display2();
//Pin description
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P1^0;
sbit E = P1^1;
current_byte++;
// Main program
void main(void)
TH1=0XFD;
SCON=0x50;
TR1=1;
EA=1;
ES=1;
writedata('d');
while(1)
display();
delay(500000);
key=0;
key++;
count = 0;
delay(500000);
display2();
display_flag = 1;
key = 0;
display2();
display_flag = 1;
current_byte=0;
void cct_init(void)
void delay(int a)
int i;
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
void lcdinit(void)
delay(15000);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(4500);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(300);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
E = 1; // => E = 1
delay(150);
E = 0; // => E = 0
delay(150);
delay(650);
writecmd(0x02);
delay(1500);
